Ehh... these consumer ones are a little tougher... I don't have manual, but heres what i know.... funny thing is that ImageClass series used to be business not consumer...
Similar to the ImageClass D700/D800 series
Based on the ImageRunner 1300/1310/1670 series (not 1600 series)
Doc Feeder is nightmare to rebuild, so rebuild with (2) Rollers, Pad and Pulleys.
Fixing Assembly is similar to a LaserJet 2100 series, have to pull a couple of covers off and the glass off to get to. Don't recomend rebuilding.
Pick-Up Rollers are 'D' Rollers and last very long.
Pay attention to the Vertical Path Roller and Bushings on side behind right hand door. There is a kit for this I believe.
Be very careful when removing the sliding Scanner off of the printer. Pay very close attention to how the Ribbon cable routes through the bottom of the Scanner that plugs in to the printer unit if you have to remove it. It will get knicked/pinched/and knock off things as it slides if put in wrong (trust me.)
You will hear clicking noise when Drum waste is near full.
What do you need to know sir? Do you need a part number? Please let me know.
The glass maybe half full, but less is more...
Printer + Fax + Copier = Jack Of Many Trades,
but Master Of None
Color Copier = Not A Color Printer
InkJet MFP = Not A Fax Machine
B/W Copier = Not A Press
Finisher = Deal Closer (salesman, not accessory)
Copier Tech = Admin's Stress Ball (Scapegoat)
Looks like it also covers PC 1060 and 1080 series.
but Master Of None
