SST Connection Error - Canon 5185i Firmware Upgrade
  • ultipre
    • Aug 2025
    The 5185i printer is definitely in download mode (accessed via 2&8 upon startup) and I still get this screen...Anyone have an idea?
  • ultipre
    Re: SST Connection Error - Canon 5185i Firmware Upgrade
    FIXED issue. Now, am having more problems
    Now, I am getting "did you install new HDD?" I click no.
    Then, "Did you install HDD encryption board?" I click no.
    Then, "Serious failure occurred on HDD. Initialize, blah blah." I click "Initialize" and get following error:
    E240
    Error response:Process has ended in error.
    <<< FileName >>>
    HDDFormatALL:C:\ServTool\iRCXXXX\HDFormat\XXxxv001 3\iRCXXXX-XXxx0013-HDFormat.ift
    Module : SendFile() - 5
    Please help!
    • twinax
      • 82
      Hello,
      It is possible that with a wrong action you destroy a part of software.
      That's not a problem, try to connect SST via (star 1 & 7 star) instead of *2&8* you got a fix IP from engine, you can check and reinstall everything you want.
      Kind regards,
      Twinax
      Remember Murphy's Law.
