Hi to you all.Am working on this machine which shows paper jam immediately when the paper starts to get out of the exit rollers.The paper breaks all of a sudden and remains being held by the fuser rollers.I have replaced all the three sensors,checked all the sensor flags which are fine,lubricated the fixing bearings,and every movement of the paper is ok and no jam codes.However as the paper tries to get out of the machine say about 3-4cm it automatically stops.Any assistance requested,thanks.
IR105 JAM AT EXIT
Tags: None
Re: IR105 JAM AT EXIT
and no jam codes
Go into service mode and check Copier>I/O, Adress P010/Bit 12,13 and 14. (internal and external delivery sensor PS9/10 and Fixing feeder unit outlet sensor PS11 ) ; does it change, when activated by paper?If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions! -
Hello all of you
Does the machine show error jam related to this situation in: Copieur>Display> Jam ? If yes, send the codes.
If the machine doesn't display any jam code, that could be explained by the fact that paper has left all the sensors but it cannot exit from the machine because the delivery rollers are not turning.
Rachid."Find a job you love and you’ll never have to work a day in your life." Nagy's fatherComment
Hi guys.Am still stuck with this machine.I have changed all the sensors internal and external delivery,delivery rollers move perfectly well,but the paper just peeps out,about an inch and stops.Any more suggestions and ideas welcome,thanks.Comment
I had a ir105 in a print shop away back in the day, it would ram at the fuser , turned out that the fuser pressure had been maxed out to fuse toner to special paper the customer wanted to use. The pressure would stop the machine when paper hit the fuser nip. I never would have figured this one out if the fuser roller hadnt broken in two..Comment
Hi Teckat and all friends,the 52T gear is ok.The funny part of this machine is that the paper leaves the fuser rollers,comes all the way past the internal and external delivery sensors and tries to go thru the delivery,rollers to a distance of say an inch and stops on all paper cassettes at the same position.All bearings are well lubricated with smooth run,sensor wiring ok.Comment
Go into service mode and check Copier>I/O, Adress P010/Bit 12,13 and 14. (internal and external delivery sensor PS9/10 and Fixing feeder unit outlet sensor PS11 )If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
The problem here is the final exit because if you set the machine to 2sided mode,both sides get printed but the paper ejection becomes the problem. I have personally opened up the machine for critical observation and you realise the selonoids performing,but the paper reaches the ejection rollers and suddenly stops.Comment
Whats odd here is, that there is no jam code popping up in the history. Check the error history instead, are there new codes coming up matching the time when the jam occours?
Did you perform a DC_con reset already and reinstall firmware?If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
Is the one way clutch on the fuser exit shaft slipping?If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
