Canon IR2520 Deep Sleep
  • mramlawi
    • Jul 2011
    • 838
    Dear all ,
    im facing a wired problem in Canon IR2520 the problem is when i turn the machine on and copy /print everything ok , about an hour the machine goes on a sleep mode the Green LED still lighting but when i come to the machine and press the on/off key which located on the panel the machine didnt wake up till i turn all the machine off and then turn in on back to work,also if i left it i do the same problem .
    what i did ?
    1: first off all i stopped all the timers from function key
    2: i removed the UTP Cable and let the machine singal i guessed maybe some virus do this
    3: i update thre Boot Rom and made software
    4: i replaced the machine with a new one also still facing the same problem and this made me crazy
    P.M : i have the same model of the machine at the same client and same department and didnt face problem
    any help ??
    Regards,
    Distinguished road makes you jewel in rough
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Canon IR2520 Deep Sleep
    Can be a local network issue.First you can do,install latest firmware and turn off network discovery.
      • 16083
      Sleep mode is a useless program/ u don't extend consumables/or save money
      To disable Sleep Mode on the machine:
      Additional Functions, 2 and 8 simultaneously, then Additional Functions.
      2. Select COPIER.
      3. Hit OPTION.
      4. Press USER.
      5. Look for the SLEEP option. Change the value of SLEEP from 1 to 0.
      6. Hit OK.
      7. Reboot the machine.
      or if available-Change ENERGY CONSUMPTION to High in user mode.
      Additional functions>Common settings>Energy consumption in sleep mode>High.
      or RE FORMAT HD/ RE LOAD FIRMWARE
      • mramlawi
        • Jul 2011
        • 838
        2. Select COPIER.
        3. Hit OPTION.
        4. Press USER.
        6. Hit OK.
        Sorry Teckat seems that u miss in model this is IR2520 and there;s no Option on the service mode in this ???or there's and its hidden in some where dont know where .
        thanks any way
        • zoraldinho
          • Mar 2008
          • 5007
          IR 2520 have standard numeric fax service mode.I hate this.
          • arielcanon
            • Mar 2012
            • 106
            Lol, I also faced this problem too, and not solved yet, I just disabled sleep timer.
            Learning never ends..
            Never give up, where there is a wheel there is a way..
            • mramlawi
              • Jul 2011
              • 838
              Dear all ,
              sorry for being late ,but the problem is solved when we change its location to another location ,that was the electricity problem by the way it was at IT department and they have regulator but dont know why this happen .
                • 16083
                late
                or last, adverbadjective 1. occurring, coming, or being after the usual or proper time: late frosts; a late spring.
                2. continued until after the usual time or hour; protracted: a late business meeting.
                3. near or at the end of day or well into the night: a late hour.
                4. belonging to the time just before the present moment; most recent: a late news bulletin.
                5. immediately preceding the present one; former: the late attorney general.
                adverb 9. after the usual or proper time, or after delay: to arrive late.
                10. until after the usual time or hour; until an advanced hour, especially of the night: to work late.
                11. at or to an advanced time, period, or stage: The flowers keep their blossoms late in warm climates.
                12. recently but no longer: a man late of Chicago, now living in Philadelphia.
                Synonyms
                1. tardy; slow, dilatory; delayed, belated.
                • mramlawi
                  • Jul 2011
                  • 838
                  [ATTACH=CONFIG]17351[/ATTACH]
                  late
                  Synonyms
                  Sorry
                    • 16083
