IRC 2020 drum issue
  • Gerhard
    • Oct 2009
    • 99
    [CQ] IRC 2020 drum issue
    Hi All
    I have had two of these machines give me +- 25K on the black drum. The problem that I have is one of ofsetting. It looks like the coating of the upper fixing roller has peeled of and it is ofsetting (ghost image) whatever comes in its path. The problem was solved by replacing the black drum (two different machines)
    Please advise
    Thanx in advance
    sigpic
    Life is a Journey enjoy the ride !!!
    • 16083
    Re: IRC 2020 drum issue
    Originally posted by Gerhard
    Hi All
    Please advise
    Thanx in advance
    imageRUNNER ADVANCE C2020 / C2030
    As the residual toner accumulated on the Upstream Brush increases, potential cannot be equalized when outputting solid white and solid black after transferring to the ITB so that the failure occurs. This may cause a "Drum Ghost".
    1. Specify the color with which ghost occurs by visual check
    2. Increase the level of Upstream DC bias by 1
    (L2) COPIER>ADJUST>HV-PRI>USUB-xDC
    3. If the trace of Upstream Brush has not disappeared, decrease the level of Upstream DC bias by 1
    4. Decrease the amount of toner deposit
    (L2) COPIER>OPTION>IMG-MNCON>TNR-DWN
    5. If the issue still persists, replace the Drum Unit of the specific color
    6. Return the service mode setting value to the default
    The imageRUNNER ADVANCE C2000 Series incorporates a new cleaner-less drum system. The drum uses a brush to recover toner that has been left during the ITB transfer process without needing to provide the toner recovery path. This results in a longer life for the drum and contributes to the models compact size.
    • Gerhard
      • Oct 2009
      • 99
      Thanx I will give that a try !!!
      Regards
      sigpic
