ir 1020 blank copie
  • jose dai
    • Dec 2008
    • 25
    ir 1020 blank copie
    canon ir 1020 making blank copies,no error no jam, pls help
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5009
    Re: ir 1020 blank copie
    Make sure that the laser shutter is opening properly. It's operated by a feature on the cartridge.
    • jose dai
      • Dec 2008
      • 25
      i removed the shuter to make sure that the shuter is waking properly,but still keeping blank nothing change.
      • cableties
        • 35
        Check devoloping unit spring compression part number fu6-2833-000
        • Jamesu
          • Mar 2012
          • 101
          Is this a brand new machine?
          Have you tried turning it off and on? No...Oh, it works now!
          • Rachid.Akli
            • Oct 2011
            • 595
            Hello,
            1- Is this common to copy and print?
            2-Try to mark the extremities of the developing and the drum cylinders an make sure they're turning.
            3- As i worked a little on these models, i noticed that the transfert roller gets blocked. Verify if it rotates easily.
            Rachid.
            "Find a job you love and you’ll never have to work a day in your life." Nagy's father
