canon 1215 E000 error code
  • dannet
    • Oct 2011
    • 22
    [Error Code] canon 1215 E000 error code
    hai, technical people kindly help me sort out the error code e000 and what could be causing the same code..
    thanks
    dannet
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: canon 1215 E000 error code
    Inspect the fixing unit.
    Clear the error.
    • doktor
      • 214
      I think this is Canon NP 1215.
      On the left hand side is a small cap.Under the hood is a small button that you push when machine is off.Turn on machine and drop the button.
      • jummamaster
        • Mar 2009
        • 99
        All fixing related codes and their reset procedures have been discussed here:
        Printer Diary: Canon Error E000, E001,E002, E003, E007
        Ricoh Error Codes
        Canon Error 5100
        Canon Error B200
        j
        c
        • gensys
          • Jan 2011
          • 323
          http://www.copytechnet.com/forums/ca...27-np6230.html
          The Road will be Mastered by >>> the Going...
          • gensys
            • Jan 2011
            • 323
            Need to Read Forum Rules
            • zoraldinho
              • Mar 2008
              • 5015
              Clear the error.
              Execute ‘#4 PRINTER RESET” under ‘#7 PRINTER’ in service mode to
              clear the error.; then, turn back on the power.
              OMG.
              NP model?? Sorry. Error clearing is for ir 1200 series.
              • gensys
                • Jan 2011
                • 323
                omg.
                Np model??
                [ATTACH=CONFIG]15000[/ATTACH]
                old, good np1215
                [ATTACH=CONFIG]15002[/ATTACH]
