Need step by step directions for connecting irc 4080 to LAN
  • jim salter
    Bought used Canon irc 4080. Need to connect it to computer via Local Area Network. LAN uses a switch and CAT5 cable. Service manual (page2-2) not much help. Is there an instruction manual that would cover this ? If not, can you give me some basic step by step directions ? Thanks, Jim
    • 16083
    Re: Need step by step directions for connecting irc 4080 to LAN
    iR4080 Brochure.pdf
    -1. do u have a imagePass Fiery H1 / or ColorPASS GX100 connected-
    -2. or do u have a Network Multi-PDL printer kit installed
    • jim salter
      Originally posted by teckat
      [ATTACH]15005[/ATTACH]
      [ATTACH]15006[/ATTACH]
      Thank you so much for giving answer to my 3/28/2012 plea of "Need step by step directions for connecting irc 4080 to LAN" You asked what kind of RIP. One machine has a Fiery and I don't know what type RIP is on the Non-Fiery machine. I was able to connect the non-Fiery useing the mamual you sent.
      Screens 1 thru 3 on page 2-7 of the manual are pretty much alike on both machines, but on the fiery machine screen 4 says "use PASV mode for FTP". This seems to toggle off or on. I don't know what it means or how to get to any meaningful TCP/IP screens. Can you provide some guidence ?
      I have screen and machine photos if they would be helpful, but I don't know how to send them to you. Should I try to post to my thread ?
      Thanks, Jim salter
        • 16083
        Thanks, Jim salter
        if the printer has no box attached to back >it has no rip& probably has a Multi Pdl Kit installed-
        in which u have quoted> has been set up already-
        for the Fiery H1 set up>
        follow instructions exactly as written>
        imagePass H1 Install.pdf
