Gp200 ....this one is old.
  • dpepin
    • Dec 2007
    • 51
    Hi you there!
    i have a customer that has a gp200. the problem is the
    machine keep loose it's memory. like fax setup,service mode adjusment,ect. I think the problem is the battery back-up, but i don't know where it is located. do you guys know where i'm suppose to look?
    thanks
    Denis
  • lkrsardis
    • Dec 2007
    • 316
    gp200 help
    This should Help
    Like the United States Postal Service It's a miracle it works!
    • dpepin
      • Dec 2007
      • 51
      thanks
      thanks Ikrsardis i really appreciate your help.
      Denis
        • 23008
        You know, 8 years is about right for a backup battery. I like that theory. It's easy enough to put you VOM on the battery and see if it holds any voltage.
