iR1600 image problem
  • DadO
    • Dec 2007
    • 404
    Hello Techs. I have problem on ir1600 where blending occurs 2 cm from the edge in sub scan. That " blending" is like u can see letters but in extreamly low density (poorly visible)
    Developer is ok, few lines across it but there's toner on both edge
    After drum where changed same thing.
    Optics cleaned
    Only one thing stayed i didn't clean was a laser unit.
    Machine have (lol or rolf or haha) 270k copes.....
    Any similar problems?
  • lkrsardis
    • Dec 2007
    • 316
    ir1600
    If this machine is in a nasty environment it may very well be the laser needs cleaning,but at 270k you will probably need a transfer roller, these are often not replaced at a regular interval. The book say's 150K for the transfer roller and the dev. unit.
    Like the United States Postal Service It's a miracle it works!
    • Canuck
      Tech Specialist
      • 1713
      Print some test prints in service mode to see if its from the print engine or the reader. If the prints are good,then you have a reader problem...do ccd adjustment,shading....watch when its scans. I've had the guide clips on the CIS fall off and cause scan problems..they ride on the bottom of the platen glass.
      • logonjim
        • 136
        ir1600 problem
        do as Ik said clean the laser unit is easy enough to do and makes a huge difference to copy quality.. just be careful when you open it done lose the laser shutter .
        • DadO
          • Dec 2007
          • 404
          I replaced Tr-roll 2 weeks before problem occurred so part 1 eliminated (but will check)
          I hope laser will help me this time....cis is waay out expensive and i think they will refuze since i changed complete fuzing unit last time(thermistor blow) since i couldn't find ther. svitch except fuz. rollers
