IR2525: 8mm white band in prints and copies Just after installation.
  • Rachid.Akli
    • Oct 2011
    • 595
    Dear all
    We recently installed an IR2520 and the first print and copy come with an 8mm white bande at the middle. Obviously, we changed the laser. The same band is still there. With not much conviction, we replaced the developing assembly. The band disepeared ?????
    Read the attachment.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
  • teckat
    • 16083
    Re: IR2525: 8mm white band in prints and copies Just after installation.
    Since it may result in unexpected accidents or injuries, do not perform any operation unless otherwise specified in the manual.
    Improper operation or use of this machine could result in personal injury and/or damage requiring extensive repair that may not be covered under your Limited Warranty
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5017
      Post a white band issue please.
      • arielcanon
        • Mar 2012
        • 106
        lucky you, you have another spare parts, so that easily to solve the problem. Good job, thanks for share...
        Learning never ends..
        Never give up, where there is a wheel there is a way..
        • spectraindo
          • May 2008
          • 313
          When installing the iR2500 series you must go to Service Mode to : #CLEAR > ENGIN > TNRINST to supply Toner to the developing unit.
          Are you a trained tech ?
          • arielcanon
            • Mar 2012
            • 106
            hello my man, your post has no relation with poster..., installing toner is a must, unless you'll get blank copy...
            • Rachid.Akli
              • Oct 2011
              • 595
              Originally posted by zoraldinho
              [ATTACH=CONFIG]15269[/ATTACH]
              Sorry for the print quality, this the best i found.
              Rachid
