E0013-0000 code in IR 6570
  • manoj1686
    • Jan 2011
    • 22
    E0013-0000 code shown in IR 6570
    am replace Waste toner bottle and clean drum unit and waste pipe
    pls help me
  • jiongpao
    • May 2009
    • 413
    Re: E0003-0000 code in IR 6570
    should check on main thermistor. Normally when this happen i will clean up those 3 things together - sub thermistor, main thermistor and thermostat. You can try to clean those with autosol liquid. If the problem still the same u might need to change main thermistor.
    • manoj1686
      • Jan 2011
      • 22
      am sorry code is E0013-0000
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5007
        Re: E0013-0000 code in IR 6570
        The waste toner pipe is identified as being clogged.Use wacuum cleaner.Check the connector for any fault in connection.Check the waste toner feedscrew lock detecting switch.
        • teckat
          • 16083
          check the switch position
          • mramlawi
            • Jul 2011
            • 838
            check the switch position and the sensors
            Distinguished road makes you jewel in rough
            • montana
              • Aug 2008
              • 392
              clean the sensor and the transparent side of the bottle.........
              • bad78
                pls help me
                • spectraindo
                  • May 2008
                  • 313
                  Check the waste toner pipe and coil spring inside pipe.
                  Clogged toner can damage the spring.
                  See pdf
