should check on main thermistor. Normally when this happen i will clean up those 3 things together - sub thermistor, main thermistor and thermostat. You can try to clean those with autosol liquid. If the problem still the same u might need to change main thermistor.
The waste toner pipe is identified as being clogged.Use wacuum cleaner.Check the connector for any fault in connection.Check the waste toner feedscrew lock detecting switch.
