iR105 problem with the original black with white copies
  • therock
    [Misc] iR105 problem with the original black with white copies
    helloI have aproblem with acanoniR105, copiescome out withblackbackground,andchangedeveloping sleeve, ringwork,the lampof the scannerworks,does not markerrorlablackbackgroundcopy isstillwith originalwhite.
    requesthelpthank you very much
  • charm5496
    • 2387
    Re: iR105 problem with the original black with white copies
    did you check to see that the pre-exposure lamps are turning on during the sequence? check the wiring through the AP unit as it gets old and can cause a poor connection.
    did you run any internal test pages or try to print from a PC to see if the engine is having issues?
    • therock
      and check it, work well pre lamps Exposure is more margins are marked on the copy funcinan showing that the problem is that it leaves the copy but with dark background
      • COPIERTEC ASSOCIATES
        • Aug 2011
        • 279
        I once had a similar problem which was caused by bad toner.Try to change the toner.
