Canon Ir 3045 Jam code 107
  • kstan268
    • Apr 2012
    • 85
    Can anyone here canhelp me to solve this problem jam code 107 double side jam ,i m using 70gsm paper right now,,I heard someone said there is a drum claw fit at the drum unit to prevent paper goes into the drum,is it true??Where can i bought it??
  • kstan268
    • Apr 2012
    • 85
    Re: Canon Ir 3045 Jam code 107
    Originally posted by Canon.Tech
    70GSM is too thin especially for double siding, you will never get the machine to run reliably on that weight.
    Use 80gsm this is the standard.
    I tell my customers to use 100gsm & that runs perfectly for long duplex runs.
    Is there another way to solve this problem beside then changing paper quality??My customer deny to change the paper!!The reason is the previous machine is Ir3300 which is has no problem in double side copy with 70gsm paper!Pls help!!
    • arielcanon
      • Mar 2012
      • 106
      yeah..., wasting time to solve this problem... (up 60 minutes), I also faced this problem a month ago.
      paper size = A4 duplex. I suggested customer to change to 80gr, but they rejected, because there was another machine which also used 70gr, no similar issue. lucky me, after changed to A4R, the problem's solved, maybe you can try to change to A4R size...,
      Learning never ends..
      Never give up, where there is a wheel there is a way..
      • jacky_kuo
        • Aug 2011
        • 54
        Do you referring to this kit ??
        this kit only sale in asia country ..
        i do not know that kit can or not to order in other country???
        this kit to prevention jam code 0107 is very prefect...
        • kstan268
          • Apr 2012
          • 85
          [ATTACH=CONFIG]15535[/ATTACH]
          Yes this is the one ,can u tell me what is the part no of this parts,they sell this item about 230 Ringgit Malaysia
          • kstan268
            • Apr 2012
            • 85
            I know A4R will solve the problem ,the fact is the printing will be very slow(double side copy)and drum will get line very fast,My customer is a copy center owner every penny he is counting if i tell him to change to 80gsm paper i think he will jump up the table ang hang him self hahahah
            • arielcanon
              • Mar 2012
              • 106
              yes.. you're right change to A4R size will get line fast on drum surface, but I don't have a choice coz my customer also refused to change paper weight to 80gr, It's difficult to get that Kit in my city, having that kit will be my choice instead of changing paper weight..
              • jacky_kuo
                • Aug 2011
                • 54
                This modify kit need sell 3 parts :
                1. screw x 3 , Parts No.:xa9-0679-000
                2. drum claw plate x 1 , parts No.:fl2-6600-000
                3. drum claw assembly x 1 , parts No: sorry i forget , search it on monday then tell on the forum .
                • jiongpao
                  • May 2009
                  • 413
                  Wondering why ya guys machines are so well clean
                  • jacky_kuo
                    • Aug 2011
                    • 54
                    1. screw x 3 , Parts No.:XA9-0679-000
                    2. drum claw plate x 1 , parts No.:FL2-6600-000
                    3. drum claw assembly x 1 , parts No: FM3-4352-010
                    there is a saying in our country , is
                    "you love it , it will love you "
                    • kstan268
                      • Apr 2012
                      • 85
                      Thanks for the part numbers, i'll order this kit & give it a try!
                      Did you manage to order the parts??how much will it cost??
                      • jiongpao
                        • May 2009
                        • 413
                        3. drum claw assembly x 1 , parts No: FM3-4352-010 "
                        Im looking for this parts also wondering where can i order from. Our supplier from singapore doesnt carry these parts
                          If you can find a UK supplier mate, post back.
                          • jacky_kuo
                            • Aug 2011
                            • 54
                            China !!!
