Hooked up new router... now Canon IR5000 no longer prints?
  • bretstar
    • Aug 2025
    We were having some wireless connection problems at the office and someone suggested it may be the wireless router. I went out and upgraded to a Linksys E2500 router and the wireless connection problem disappeared. Everyone is able to access the wireless network now and it's stable. HOWEVER, now no one is able to print the Canon IR5000. I have no idea what happened to have caused this... Any ideas?
    If this helps, the Canon IR5000 is connected to into the wall with a blue Ethernet cord. Is there something else I need to do to get it to print? I didn't know switching the router would cause this problem.
    Thanks!
    • 23009
    Re: Hooked up new router... now Canon IR5000 no longer prints?
    Did you change IP address range? On your computer go to the Command Prompt and enter: ipconfig/all
    then Enter. The computer will show the IP address of your computer.
    Now go to the MPF and print off a Configuration Page. What address is it set to?
    Example #1:
    IP address: 192.186.1.100
    Subnet Mask: 255.255.255.0
    Gateway: 192.168.1.1
    Example #2:
    IP address: 172.24.28.100
    Subnet Mask: 255.255.0.0
    Gateway: 172.24.28.1
    Note the differences in the Subnet Mask. The highlighted parts must be the same, identical on both the MFP and your computer. The regular text parts must be different.
    If you must select a new address for the MFP, choose a number in the 200's (between 200 and 253). To test for availability: in your Command Prompt window enter: ping 192.168.0.200
    then Enter. If you get a response in milliseconds (ms) that one is already being used. If you get Timed Out, that one is available.
    You may need to change the IP address and possibly also the Subnet Mask and Gateway, on the MFP. Also in the print driver > Properties > Ports > Add a Port > Standard IP Network Port > then enter the new IP address > Enter/OK etc.
    Does that help? =^..^=
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Just a thought (dangerous, I know), but I'm thinking that the iR5000 may either have only a 10MB card in it, or may be locked at 10MB. Keep in mind that the iR5000 is no spring chicken.
      From what I saw on line, the E2500's wired ports look like they may not support 10MB.
      But.... if you've been able to ping the Canon, that's not the case, and would mean that the two are connected.
      Then again, blue eithernet cords spell trouble. Yellow ones work much better.
      • bretstar
        @ blackcat4866:
        Thanks for the fast reply! I didn't change any IP address ranges, I simply just hooked up the new router, put the setup CD in, and went through the simple process.
        I've gone into CMD and done ipconfig /all and see a few different things...
        Windows IP Configuration
        Ethernet adapter Local Area Connection
        Tunnel adaptar isatap.ph.cox.net
        etc.
        Under "Ethernet adapter Local Area Connection" I see my IPv4 address as 192.168.1.102. My subnet mask is 255.255.255.0. And gateway is 192.168.1.1.
        My other question for you is what is the MFP? What does that stand for? I need to make sure the changes I'm making is going to work for all computers here in the office, not just mine.
        Thanks!
        @KenB:
        You may be on to something there... I've never been able to ping the Canon with the new router installed... I actually don't know how to ping the router, but ever since the new router was hooked up today, the printer has been completely unresponsive to print requests from all computers. So you think it could be the E2500 router that is causing all this?
          • 23009
          Multi-Functional Printer: the Canon iR5000 =^..^=
            • 23009
            I didn't think about that. Check the documentation to see if your router can communicate at 10 MBs.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              You would ping the copier from your PC. Even tough the router does have it's own IP address, you don't normally need to tangle with it.
              My Linksys home router, for instance, is 192.168.1.1. The DHCP function of it starts giving out 192.168.1.100, 192.168.1.101, an so on.
              BTW... "MFP" can either stand for "Multi Function Product", or "Multi Function Printer", depending on who you ask.
              • bretstar
                You two have both been so helpful! I think you both are figuring it out here...
                So I went to my printer properties for the iR5000 and went onto "Ports" and found the address is 192.168.0.108. So I went into CMD and pinged that and it did not go through. Got the request timed out message. 4 packets sent, 0 received. I made a screenshot showing everything here: http://i.imgur.com/gRbSp.jpg
                So I'm going to guess it's that the router is not capable? That it can't communicate at 10 MBs? I'll check my router manual and see if I can find something about that as well, but since it can't ping, I'm assuming it must be the router? Is that an accurate assumption?
                  • 23009
                  For starters the MFP is not within range.
                  The correct range would be 192.168.1.108
                  You'll need to change the port in the driver and to change the IP address and Gateway in the MFP. Then you'll find out if it can communicate. =^..^=
                  • bretstar
                    I'm not sure what you mean by that? I'm not much of a printer guy and not really the best technology guy either. I can usually "Google" my way around a problem and find a solution, but can't find anything on this topic.
                      • 23009
                      Sorry, I submitted my response before it was a complete thought.
                      • jarwil
                        • Jun 2009
                        • 61
                        your computer is 192.168.1.102 and your printer is 192.168.0.108.
                        If you change the printer to 192.168.1.108 then it will be in the same range and most likely be able to ping and print. Or any available address on 192.168.1.???.
                        Need to also change printer port to refelct change in printer driver
                        Hope this helps
                        • bretstar
                          Can you guide me in the right direction to where I would go to change that IP?
                          I'm able to change my "Printer Name or IP Address" but not the "Port Name". The Port Name box cannot be edited it seems like. http://i.imgur.com/t7Ebx.jpg
                          • bretstar
                            No worries, I see your full response now. Could you guide me in the right direction of where I would go to edit the IP address to the correct one that you provided me with?
                            I was able to edit just one of the boxes, not both of them. http://i.imgur.com/t7Ebx.jpg
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3944
                              Not to make the waters even muddier (but, hey, somebody's gotta do it, amirite?), but you have installed the iR5000 L1 PCL driver, which is for the optional Fiery print controller.
                              From what you've posted so far, it looks like your machine is using the embedded print controller, which is different. Although you would get output from that driver, there are no guarantees.
                              You can get the correct drivers from the Canon USA site. (We can help you with that if need be.)
                              First things first, though. Let's get this talking on the network first.
