ir3300 will not print over network win7 x64, tearing my hair out...
  • captaintofuburger
    • Aug 2025
    I have a few ir3300's at a location and I just finished setting up a new win 7 x64 pro terminal for use. However I cannot for the life of me get it to print correctly. I have tried the PCL5 and 6 drivers but nothing seems to work.
    When printing the copier will claim there is no paper in the try, opening up the system monitor on the copier you can see it's full, press ok, and it will print without any problems. Some drivers in win7 will also tell me there is no paper in the copier even though it's full.
    I have several other machines, even win7 x64 that print without any issues to it, so I'm guessing it's a driver issue. I even manually pulled the driver off another x64 machine (someone set it up to use a ir3530 pcl driver) that prints without any issues and I still get the same problem.
    I'm totally out of ideas that this point.
  • captaintofuburger
    Re: ir3300 will not print over network win7 x64, tearing my hair out...
    I think I have it solved, I switched from auto detect the paper to use tray 1, printed without issues. Switched it back to auto, and it seems to work now.
    • CaptnRed
      • Apr 2011
      • 57
      Hope you have some hair left to grow, thanks for post on the solution. I have a fleet of these suckers, and may run into the same problem.
