LCD Access
+ More Options
Posts
  • V-P
    • Apr 2011
    • 679
    LCD Access
    Hi Fellas,
    I am having an issue with a LCD display of a iR4570.
    I can access till TOUCHCHK but I can NOT hit OK. It is impossible to hit Ok - I tried everywhere on the screen.
    Is there anyway to overcome this ?
    <Operating procedure>
    - Align the press positions on the touchpanel and the coordinate positions on theLCD section.- If the LCD section has been replaced, execute this service mode.1) Select TOUCHCHK to reverse its display. Then press the OK key.2) Press sequentially the nine positive signs (+) that appear on the touchpanel in
    order.
  • A15xand3r
    Re: LCD Access
    Hi, I've had the same problem a couple of times, the OK button has moved out of the LCD screen area. Their is nothing you can do that I could find apart order a new LCD.
    • northernlife
      • Sep 2011
      • 847
      Re: LCD Access
      save yourself a couple hundred bucks and just change FK2-0329-000 ANALOG TOUCH PANEL UNIT and FC5-4458-010 SHEET, LCD ELECTROSTATIC.
      If the screen still turns on just change the membranes and you'll be good to go.
      Let me know how you make out
      Jas
      • arielcanon
        • Mar 2012
        • 106
        Re: LCD Access
        I also faced this problem in the field, I just cleaned LCD display and touch panel unit..., hope you succeed too
        Learning never ends..
        Never give up, where there is a wheel there is a way..
          • 23010
          Re: LCD Access
          There's got to be an engineer out there laughing his ass off. "I know! I'll put the touch screen alignment access button available only from the touch screen. The techs will rip out their hair looking at the button that doesn't work!"
          • V-P
            • Apr 2011
            • 679
            Re: LCD Access
            "There's got to be an engineer out there laughing his ass off. "I know! I'll put the touch screen alignment access button available only from the touch screen. The techs will rip out their hair looking at the button that doesn't work!""
            I was actually thinking the same thing...
