Lifter not working on Unit-AE1 (wtih Canon iR2520)
  • Quarath
    • Jul 2025
    Re: Lifter not working on Unit-AE1 (wtih Canon iR2520)
    All three cables connect to the machine you have no socket in copier body for cable with the black sleeve !
    To the right of the blue / red cable
    The machine either has this cable missing or not fitted correctly.
    Unusual to say the least.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      • mramlawi
        • Jul 2011
        • 838
        some of cables not connected it happened with me once
        Distinguished road makes you jewel in rough
        • Quarath
          This is from the Unit-AE1 installation manual - see the MEMO. So i suppose the black cable doesn't have to be connected.
          • V-P
            • Apr 2011
            • 679
            I recently did an installation of the same configuration as yours.
            And yes - the black cable is NOT connected.
            BUT - did you install the Power Supply Unit ???
            • Quarath
              Originally posted by V-P
              I recently did an installation of the same configuration as yours. And yes - the black cable is NOT connected.BUT - did you install the Power Supply Unit ???
              Oh great...thanks for pointing it out - there is no mention on either the manual or our local Canon webpages that a power supply is required.Even when ordering this printer they didn't warn me that I will need the power supply - they obviosly didn't even know i will...
              • V-P
                • Apr 2011
                • 679
                You are right to some degree.
                Canon should have more info, but if you read the installation manual of the AE1 Unit, you will find it there.
                Next time pay more attention
