canon IR-1020 error E-100
  • tariq65
    • Jun 2010
    • 84
    hello every one i have canon IR-1020 get system error E-100 how to solve plz help me.thank
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: canon IR-1020 error E-100
    Check for condensation on the BD sensor
    Check the connector of the BD detection PCB.
    - Replace the laser scanner unit.
    - Replace the DC controller PCB.
    • montana
      • Aug 2008
      • 392
      hi....the sm says(E100 0000 BD detection PCB failureThe BD detection PCB is faulty. - Check the connector of the BD detection PCB.
      you have also to check the drum cart if it is in correct position..the dusty reflectors in laser scanner
      may cause this error
      have a good luck
      • Rachid.Akli
        • Oct 2011
        • 595
        Have a look on the attachment.
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • zoraldinho
          • Mar 2008
          • 5015
          Rachid.
          If the shutter is not open on this model get only blank pages,not an error if i remember wright.
          • Rachid.Akli
            • Oct 2011
            • 595
            I've never encountered E100 error code in this model. I've deduced this by analogy with iR1600 model. So, You're, may be, right.
            Rachid.
