hello every one i have canon IR-1020 get system error E-100 how to solve plz help me.thank
canon IR-1020 error E-100
Re: canon IR-1020 error E-100
Check for condensation on the BD sensor
Check the connector of the BD detection PCB.
- Replace the laser scanner unit.
- Replace the DC controller PCB.If it ain't broke, don't fix it
A picture is worth a thousand words -
hi....the sm says(E100 0000 BD detection PCB failureThe BD detection PCB is faulty. - Check the connector of the BD detection PCB.
you have also to check the drum cart if it is in correct position..the dusty reflectors in laser scanner
may cause this error
have a good luckComment
Have a look on the attachment.
Rachid.Attached Files"Find a job you love and you’ll never have to work a day in your life." Nagy's fatherComment
