Canon 5870C error code E79-002
  • bojans
    • 1313
    Hi,
    Today I went to my friends who have warehouse with bunch of copiers.
    They tried to turn on Canon 5870C, but there was error E00079-002 and touch panel didn't react on touch.
    Could someone please give me code explanation, and advice if this model is worth fixing? Or they should throw it in the trash.
    Thank you
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Canon 5870C error code E79-002
    This is code explanation by manual:
    If there is an open circuit in the home position sensor of the
    outside heating roller home position sensor, the state of the
    sensor will be identified as being ON.
    An error will be identified if the sensor fails to go off when
    it is at a point where it must normally go on and the outside
    heating roller shift motor is driven.
    I'm not huge fun of this model
    • bojans
      • 1313
      Thank you Zoran.
      • zoraldinho
        • Mar 2008
        • 5015
