Error code 000013-0000 in ir 6570
  • bluesky2000
    • 95
    HI all
    i have this problem in ir 6570 :
    my problem with this error 000013-0000
    how can i fix it ?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Error code 000013-0000 in ir 6570
    The waste toner pipe is identified as being clogged.Use wacuum cleaner.Check the connector for any fault in connection.Check the waste toner feedscrew lock detecting switch.check the switch position.
