Measure to Prevent a Black Control Panel Display at Power Switch-On
imageRUNNER ADVANCE C2020
FAH00500 ~ FAH02992
FAH10000 ~ FAH10009
imageRUNNER ADVANCE C2030
EZS00500 ~ EZS02599
EZS10000 ~ EZS10299
The control panel LCD is blacked out even though the green power LED is lit at power switch-on.
When rewriting to the SATA_FLASH, which occurs frequently, and the count of rewriting reaches the
upper limit, the controller chip on the SATA_FLASH PCB outputs a warning status causing the BIOS on
the main controller to stop during start-up.
Upgrade to Firmware Ver.30.06.01 or higher
READ PDF>>>>TP12-.pdf
FAH00500 ~ FAH02992
FAH10000 ~ FAH10009
EZS00500 ~ EZS02599
EZS10000 ~ EZS10299
