iRUNNER ADVANCE C2020/2030-Prevent a Black Control Panel Display at Power Switch On-
    • 16083
    [Electrical] iRUNNER ADVANCE C2020/2030-Prevent a Black Control Panel Display at Power Switch On-
    Measure to Prevent a Black Control Panel Display at Power Switch-On
    imageRUNNER ADVANCE C2020
    FAH00500 ~ FAH02992
    FAH10000 ~ FAH10009
    imageRUNNER ADVANCE C2030
    EZS00500 ~ EZS02599
    EZS10000 ~ EZS10299
    The control panel LCD is blacked out even though the green power LED is lit at power switch-on.
    When rewriting to the SATA_FLASH, which occurs frequently, and the count of rewriting reaches the
    upper limit, the controller chip on the SATA_FLASH PCB outputs a warning status causing the BIOS on
    the main controller to stop during start-up.
    Upgrade to Firmware Ver.30.06.01 or higher
    READ PDF>>>>TP12-.pdf
  • montana
    • Aug 2008
    • 392
    Re: iRUNNER ADVANCE C2020/2030-Prevent a Black Control Panel Display at Power Switch
    Thanks for the tips mr teckat.............
