remote diagnostics
  • nogood boyo
    • Mar 2012
    • 156
    [Misc] remote diagnostics
    I am in charge of 62 canon machines (8 different models) all spread out on the same network.
    Is it possible to set up some sort of automatic ... remote notification system that notifies me of the meter reads or copy counts? My computer is on the same network.
    Or is this something that i am just going to physically have to do once a month via communication with the machines key operators and the RUI?
  • teckat
    • 16083
    Re: remote diagnostics
    imageWARE Remote
    'imageWARE Remote' is a service that collects the page counter, service part counter, alarm, jam, and error code data from Canon devices with the embedded Remote Diagnostic System (eRDS).
    The eRDS, built into recent eRDS enabled Canon imageRUNNER devices, enables a device to transmit counter and error code data to a Universal Gateway (UGW) database. The Dealership can retrieve the data from the UGW via a web portal. This data can be used to enhance the billing work flow or service work flow of a Canon authorized reseller.
    SEE PDF>>>>>>>>>>>>>iW_Remote_SSGl.pdf
    eRDS provides the following benefits:
    Automatic Meter Reading
    eRDS captures and provides meter data automatically via the network to the UGW, reducing the need for manual collection of meter readings by the customer and reporting them to the dealer for billing purpose.
    Enhanced Service Offering
    Automatic Error, Jam, and Alarm Notification can be used to improve dealer's response time.
    Usage Statistics, Parts Lifetime and Consumables Management
    As part of the imageWARE Remote Services Monitor feature, providers have access to information on parts usage of their customers' registered imageRUNNER devices. This can be used offer preemptive service to the customer, before consumable and durable parts reach the end of their expected life cycle. In addition, information about toner usage allows the service provider to make suggestion about re-ordering or stock quantities.
    imageWARE Remote offers these options:
    1. imageWARE Remote Meter Reading - This system communicates the counter information to the UGW database for review by the dealership.
    2. imageWARE Remote Service Monitor - This system includes the same service as imageWARE Remote Meter Reading with the addition of transmitting device alarm, jam, and error codes for review by the dealership.
    imageRUNNER and imagePRESS devices that were released after November 2008 have e-RDS support.
    For imageRUNNER and imagePRESS devices released before November 2008, please use the following list to determine e-RDS support.
    • imageRUNNER 10231
    • imageRUNNER 10251
    • imageRUNNER 1023N1/1023iF
    • imageRUNNER 1025N1/1025iF
    • Color imageRUNNER 1022/1022i
    • imageRUNNER 2270 / 2870
    • imageRUNNER 2016 / 2020 (version 60.02 or higher)2
    • imageRUNNER 2016i / 2020i (version 60.02 or higher)2
    • imageRUNNER 2018 / 20221
    • imageRUNNER 2018i / 2022i1
    • imageRUNNER 2230 / 2830 with Printer Kit E2 or Printer Kit E33
    • imageRUNNER 3025 / 3030 / 3035 / 3045
    • imageRUNNER 3245 / 3245i / 3235 / 3235i / 3230 / 3225
    • imageRUNNER 3530 with Printer Kit E2 or Printer Kit E33
    • imageRUNNER 3570 / 4570
    • imageRUNNER 5570 / 6570 *
    • imageRUNNER 5055 / 5065 / 5075
    • imageRUNNER 5070 *
    • imageRUNNER 85PLUS *
    • imageRUNNER 8070 *
    • imageRUNNER 9070 *
    • imageRUNNER 105 PLUS *
    • imageRUNNER 7086 / 7095 / 7105 *
    • imageRUNNER C3170
    • imageRUNNER C3170i
    • imageRUNNER C5870U *
    • imageRUNNER C6870U *
    • Color imageRUNNER C2550
    • Color imageRUNNER C2880/C3380 *
    • Color imageRUNNER C2880i/C3380i
    • Color imageRUNNER C4080/C4580 *
    • Color imageRUNNER C4080i/C4580i
    • Color imageRUNNER C5180 *
    • Color imageRUNNER C5185*/C5185i
    • imageRUNNER 2025i/2030i
    • imageRUNNER 5050 *
    • imageRUNNER C5058/C5068 *
    • imagePRESS C1/C1+ *
    • imagePRESS C6000 *
    • imagePRESS C6000VP *
    • imagePRESS C7000VP*
    * These imageRUNNER models are also supported with an imagePASS controller connected.
    1 The imageRUNNER devices require the PCL Printer Kit M1 to support the e-RDS function required for iW Remote.
    2 The imageRUNNER 2016/2016i/2020/2020i models must have system software version 60.02 or higher installed to support imageWARE Remote.
    3 The imageRUNNER 30 Series models must have a Printer Kit and 256 MB of RAM installed to support imageWARE Remote.
    The supported imageRUNNER models have the e-RDS (embedded RDS) technology available. e-RDS needs to be activated.
    eRDS be activated on the Canon device in order to use imageWARE Remote----
    The Network Settings in the Canon device must be properly configured with all of the following :
    - IP Address Settings (including the correct IP Address, Subnet Mask, and Gateway Address settings).
    - DNS Server Settings.
    - Proxy Settings (if necessary).
    - SNTP Settings. (can use TIME.NIST.GOV). Some customers such as hospitals, state/local or government agencies may have their own SNTP time servers and may not permit the use of other third party SNTP servers, in those cases ask the IT dept for the correct SNTP server to use within their orginazation.
    To activate eRDS (on most supported models):
    1. Enter Service Mode (press Additional Functions, 2 and 8 simultaneously, then Additional Functions).
    2. Select Copier > Function > Install.
    3. Set eRDS to 1, then press OK.
    • nogood boyo
      • Mar 2012
      • 156
      Awesome!
      thank you so much.
      I knew ERDS existed but i didnt have any info on it.
      • vigour
        • Aug 2010
        • 1038
        EXTRA INFO
        After setting eRDs on
        go one line down RGW-PORT make sure the proper port is in use ---Default 443
        next line --- run COM TEST ----look for OK
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Hi, Gang,
          Anyone ever try to enable (or disable) eRDS remotely, without having to be in front of the machine in service mode?
          I'm thinking there may be a web page (not unlike the MEAP interface), but I've yet to find it. Could it be in iWEMC? The documentation on iWEMC isn't the greatest.
          Thanks!
          • northernlife
            • Sep 2011
            • 847
            Nope. you need to be in front of the machine to go into service mode, function> install > e-rds has to be set for 1 and then yo
            u have to do the com-test AFTER the serial number of the system has been input into ugwportal.
            What's CUSA charging per machine? Canada's charging 2 bucks a month per serial number. But well worth it. This system saves me so many unecessary calls.
            Originally posted by KenB
            Hi, Gang,
            Thanks!
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              Thanks for the reply.
              Sadly, that's what I thought.
              One question though. There is a web page on each machine, namely http://<IP Address>:8000/rds that I can't seem to get into, I always get a 404 error, regardless of the login credentials used.
              I have found no documentation on this anywhere.
              Any clue?
              (Sorry, no idea on what Uncle Canon is charging...)
              Thanks again.
              • Rakesh
                • May 2012
                • 72
                Is e-RDS software support iR2318 & 2420 Model Printer?
                Sent from my Samsung Galaxy S GT-I9000 using Tapatalk 2
                View Life As A Continuous Learning Experience...
                • zoraldinho
                  teacher-guide-expert-guru
                  • Mar 2008
                  • 5015
                  Hi, Gang,
                  Thanks!
                  If you on the same network you can use Remote Operation Kit.You can do anything without having to be in front of the machine.
                  http://www.copytechnet.com/forums/at...it-gen-855.pdf
