IR Advance C5051 Developing units
  • Zesti
    • Jun 2009
    • 308
    [Misc] IR Advance C5051 Developing units
    Hi,
    I've got a IR Adv. C5051 machine. It's 220V (EU version) machine and need to replace the dev. tanks all 4. I've got a very good offer for the tanks from US but I can see the part nos are different. Any body can advise if the US version tanks will work in EU version machine.
    TIA
  • teckat
    • 16083
    Re: IR Advance C5051 Developing units
    Originally posted by Zesti
    Hi,
    TIA
    Be Smart/ call Canon for proper information
    there are no usual notes in US Manual to indicate for use in 220v machines
    • Zesti
      • Jun 2009
      • 308
      Thanks teckat.....
      Hmmmmmm so no clue about it.....
      • Herrmann
        • Jan 2006
        • 792
        Maybe not the Voltage but the Powerfrequency is essential here. Europe 50HZ, USA 60HZ. If the maschine takes the Power Frequency as a basis to generate the Bias Frequency, you will run into Problems. I have no clue, if this method is still in use, in fact, it WAS in the late 80's. We have had a lot of hassle with cheap usa toner here in germany due to this fact.
        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
        • teckat
          • 16083
          Thanks teckat.....
          one thing I noticed about this series, is that there are different part #'s for Parts Catalogs for area related IRADC printers--
          imageRUNNER ADVANCE C5051/ 5045/5035/5030 Series(Parts Catalog)
          120V TW --------F15-4101-000 EUJ
          100V ------------F15-4111-000 DZH ----ONE-PATH ADF + READER
          120V US,CA,LTN------F15-4131-000 DZK
          120V ----------------F15-4132-000 EUF ---GOVERNMENT
          230V ----------------F15-4141-000 DZS
          230V CN------------- F15-4151-000 EUG
          230V AU------------- F15-4161-000 DZT
          230V KR -------------F15-4171-000 EUH
          230V EUR ------------F15-4191-000 DZQ
          imageRUNNER ADVANCE C5051F
          100V FAX -----------F15-4112-000 DZJ ONE-PATH ADF + READER + FAX
          imageRUNNER ADVANCE C5051i
          230V EUR ------------F15-4192-000 DZR PCL
          imageRUNNER ADVANCE C5045
          120V ----------------TW F15-4201-000 EUP
          100V ----------------F15-4211-000 DZU ONE-PATH ADF + READER
          120V US,CA,LTN -----F15-4231-000 DZW
          120V ----------------F15-4232-000 EUK ----GOVERNMENT
          230V ----------------F15-4241-000 EBU
          230V CN -------------F15-4251-000 EUL
          230V AU -------------F15-4261-000 EBV
          230V KR -------------F15-4271-000 EUN
          230V EUR ------------F15-4291-000 DZX
          imageRUNNER ADVANCE C5045F
          100V FAX ---------F15-4212-000 DZV ONE-PATH ADF + READER + FAX
          imageRUNNER ADVANCE C5045i
          230V EUR ----------F15-4292-000 EAH PCL
          imageRUNNER ADVANCE C5035
          120V TW ------------F15-4301-000 EUU
          100V ----------------F15-4311-000 EBW REVERSE ADF+ READER
          120V US,CA,LTN ------F15-4331-000 ECV
          120V -----------------F15-4332-000 EUQ --GOVERNMENT
          230V -----------------F15-4341-000 EEA
          230V CN --------------F15-4351-000 EUR
          230V AU --------------F15-4361-000 EET
          230V KR --------------F15-4371-000 EUS
          230V EUR -------------F15-4391-000 EDG
          imageRUNNER ADVANCE C5035F
          100V FAX --------------F15-4312-000 EBZ REVERSE ADF + READER + FAX
          imageRUNNER ADVANCE C5035i
          230V EUR --------------F15-4392-000 EDZ PCL
          imageRUNNER ADVANCE C5030
          120V TW -----------F15-4401-000 EUY
          100V ---------------F15-4411-000 EEU REVERSE ADF + READER
          120V US,CA,LTN -----F15-4431-000 EFA
          120V ----------------F15-4432-000 EUV --GOVERNMENT
          230V ----------------F15-4441-000 ETG
          230V CN -------------F15-4451-000 EUW
          230V AU -------------F15-4461-000 ETM
          230V KR -------------F15-4471-000 EUX
          230V EUR ------------F15-4491-000 EFF
          imageRUNNER ADVANCE C5030F
          100V FAX -----------F15-4412-000 EEY REVERSE ADF + READER + FAX
          imageRUNNER ADVANCE C5030i
          230V EUR -----------F15-4492-000 ETF PCL
          • Zesti
            • Jun 2009
            • 308
            Herrmann, The frequency is not the issue in the modern machines.
            Teckat thanks for your details. My only concern is about any special notch or any DV unit chip related to region...
            • teckat
              • 16083
              Called Canon , they can't support (won't reveal) if USA 120V DV unit will work in 230V EUR Model
              think knucklehead's name was Curly
              • Canontech
                • Aug 2009
                • 16
                Hey,
                Does any one have the part number for the cable harness between the developer and the drawer? I see in figure 600 of the parts catalog that they show the part but there is no number.
                • teckat
                  • 16083
                  Originally posted by Canontech
                  Hey,
                  what is item ## on page ??
                  FIGURE 600.pdf
                  FIGURE 600 PARTS.pdf
                  • Dan Dryer
                    • Jan 2008
                    • 57
                    Hi,
                    TIA
                    What part numbers do you have?
                    I can't see any region-specific part numbers in the manual.
                    • Canontech
                      • Aug 2009
                      • 16
                      [ATTACH]16906[/ATTACH]
                      [ATTACH]16907[/ATTACH]
                      Teckat, THANKS!
                      I must have a old version of the catalog, #50 is the item I am looking for but did not have a number in my book.
                      Thanks again.
                      • teckat
                        • 16083
                        Teckat, THANKS!
                        Thanks again.
