ERROR 00004-0103 IR 6575 help plaese !!!!!!!
  • bluesky2000
    • 95
    hi all
    my problem with ERROR 00004-0103 IR 6575
    I change DC CONTROLLER PCB and the Error still display !!!!!!!!
    Help help help
  • vigour
    • Aug 2010
    • 1038
    Re: ERROR 00004-0103 IR 6575 help plaese !!!!!!!
    Is this the same machine with E005
    Was this after a power cut, or brown out?
    Check wall voltage.
    Check your fuser carefully
    ERROR CLEAR
    If error won't clear
    Check fuse on IH power supply.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Jesterday you have E005 on the same machine.Maybe you forgot something!?
      • bluesky2000
        • 95
        Check wall voltage.
        ERROR CLEAR
        thank u man so much
        yes , it's the same machine
        what did u mean with "fuser" any fuse
        • bluesky2000
          • 95
          i have three machine
          one it's work good
          and the other have Error 00004-0103
          i don't forget any thing
          • jiongpao
            • May 2009
            • 414
            Fuser unit = heater unit = fixing unit where the place for upper roller, cleaning web roller.
            Today i did e004 and i found out the heater lamp connector didnt connect properly and thats why it keep coming out e004 even i change HVT and SSR.
            Double check the heater unit wiring and connector.
            • vigour
              • Aug 2010
              • 1038
              did you fix your E005, and ran some copies then E004 showed up
              FUSER = Fixing Unit = very hot 200 degrees C
              FUSE = A safety device that protects an electrical circuit from excessive current
              • bluesky2000
                • 95
                thanks for all
                my problem is solved , and the solve by : replaced the power supply it's work
