RE. i sensys mf4410 canon printer display e202 0002
  • MULEME STEPHEN.K
    • Oct 2011
    • 20
    Hi senior tech my printer canon i sensys 4410 when i switch it on gives me an error e 202 0002 what could be the problem help me
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5009
    Re: RE. i sensys mf4410 canon printer display e202 0002
    Contact Sensor HP error,
    Failure in return
    (1) Check the connection of Flat Cable between Main
    Controller Board (J5) and Contact Sensor.
    (2) Replace the Flat Cable between Main Controller
    (3) Replace the Contact Sensor.
    4) Replace the Main Controller Board.
    • MULEME STEPHEN.K
      • Oct 2011
      • 20
      Re: canon ir 2016
      1. my ir 2016 canon disturbs with memory full, what could be that help me guys some times it goes and after sometime it comes back so help me.
      • zoraldinho
        • Mar 2008
        • 5009
        Re: canon ir 2016
        This is your thread about MF4410.What's going on??
        Other technician need to know!
        • rado_hristov
          Re: canon ir 2016
          full memory on IR 2016 you have to solve if preinstall sistem software , generaly that is the problem .
          • teckat
            • 16083
            Re: canon ir 2016
            " Memory is Full " is indicated on the Control Panel display and the copier is locked up. ??
            see below>>>>>
            Performing ALL CLEAR in service mode clears out the message " Memory is Full " and should resolved the service message.
            To perform ALL CLEAR in service mode, enter service mode by pressing the Additional Functions key then the number 2 key then the number 8 key then the Additional Functions key again.
            #SSSW will appear on the display. Use the arrow keys and scroll to # CLEAR then select OK.
            Use the arrow keys and scroll to "ALL" then select OK. "Please Wait" will appear on the display. After awhile, the copier will reboot then come "Ready".
            or
            For Intermittently issue only, the message Memory is Full is occurring on the display of the Control Panel.
            Adding extra memory to the Image Processor pcb will resolve the Memory Full message issue.
            -For the imageRUNNER 2016 / 2020 / 2018 and 2022 the standard memory installed on the Image Processor pcb is 128MB. It is possible to upgrade to 256MB of memory.
            -For the imageRUNNER 2016 and 2020 the 128MB DDR Module has to be replaced with the 256MB DDR Module because there is only one slot for memory on the Image Processor pcb. Part number for the 256MB DDR Module is FM2-4898-000.
            -For the imageRUNNER 2018 and 2022 just add another 128MB strip of memory to the open slot, J2, on the Image Processor pcb. Part number for the 128MB strip of memory is FM3-3324-000.
            or
            "Memory Full" Message is Displayed, When Color Scanning Only
            Message may be resolved simply by re-seating the USB Flash Memory, and the DDR module on the IP board.
            • zoraldinho
              • Mar 2008
              • 5009
              This guy make me a headache. Check this thread!
              http://www.copytechnet.com/forums/ca...f-skewing.html
              • zaza
                MECANOGRAPHE
                • Mar 2008
                • 1095
                ok l have the same problems but myself mf 4410 not knowing by my computer ..xp or win7 ..l need know how can i rester all setting ....
                BEST TECHNICIAN . NICE PEOPLE .
                • teckat
                  • 16083
                  reload print drivers
