contact sensor not comming back
  • Tlemsani
    • May 2012
    • 17
    Hi every one,
    I'm having troubles with an IR1530, the problem is the following:
    the reader motor drives the contact sensor forward but does not in the other way around,
    it doesn't come back,
    any one know what it means?
    thanks in advance,
    peace!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: contact sensor not comming back
    Did you try to clean or replace HP sensor?
    • Tlemsani
      • May 2012
      • 17
      No, actually, the flat cable relating the scanner unit to the main control PCB
      PN: FF6-1443-030 was damaged,
      I replaced it, and every thing works properly now,
      thanks alot!
      • zoraldinho
        • Mar 2008
        • 5007
        Good to know.Thanks.
        • Tlemsani
          • May 2012
          • 17
          you're welcome
          peace!
