contact sensor not comming back
  • Tlemsani
    replied
    Re: contact sensor not comming back
    you're welcome
    peace!
  • zoraldinho
    replied
    Good to know.Thanks.
  • Tlemsani
    replied
    No, actually, the flat cable relating the scanner unit to the main control PCB
    PN: FF6-1443-030 was damaged,
    I replaced it, and every thing works properly now,
    thanks alot!
  • zoraldinho
    replied
    Did you try to clean or replace HP sensor?
  • Tlemsani
    started a topic contact sensor not comming back
    Hi every one,
    I'm having troubles with an IR1530, the problem is the following:
    the reader motor drives the contact sensor forward but does not in the other way around,
    it doesn't come back,
    any one know what it means?
    thanks in advance,
    peace!
