imagepress C1 error e0014-0002....
  • mark921
    • Dec 2010
    • 110
    I have a C1 which is throwing error code e0014-0002, which is a fixing motor issue according to the manual. The error started intermittent, but now occurs every time, on plain paper mode only. Heavy paper works fine.
    I have replace the fixing drive motor, as well as the belt drive motor. also replace a worn bushing in the belt drive assembly.
    Im thinking fixing driver, but wanted other opinions before ordering...
    Thanks!
  • teckat
    • 16083
    Re: imagepress C1 error e0014-0002....
    Thanks!
    did u replace the Fixing Belt Assembly
    Check the connector J814 on M36 Motor Driver .This connection does not have to be removed when taking out the Fixing Belt Assembly
    When removing the other connectors from the Fixing Driver PCB, the wire harness is pulled and the connector J814 can be dislodged accidentally-
    Have u inspected & Cleaned the Pressure Pad Cover inside the Fixing Belt Assembly and apply the correct amount of Silicone Oil -
    Also a dry and dirty Pressure Pad Cover will cause a drag on the Fixing Belt Assembly =E014-0002
    • mark921
      • Dec 2010
      • 110
      Teckat....per your suggestion, i changed the pressure pad, pad cover, and fuser belt.
      worked perfect...after a run of 500 prints, we can declare case closed!
      thanks much!!!!
      • teckat
        • 16083
        thanks much!!!!
        The Dude.jpgthanks/ & keep up the good work
