Canon IRC1022i Initialization
  • Alex ahir
    • May 2012
    • 125
    HI guys how to initialize IRC1022i. coz i want to give a static ip to the copier but when i go to the sys management it is asking a user and password. i dont know what is user and password
  • arielcanon
    • Mar 2012
    • 106
    Re: Canon IRC1022i Initialization
    Try default setting for user and password = 7654321. If failed, reset password on service mode
    Learning never ends..
    Never give up, where there is a wheel there is a way..
    • Alex ahir
      • May 2012
      • 125
      how to go to service mode on this model?
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 4964
        Use Ariel's suggestion.
        Practice makes perfect
        If you want something done right, you have to do it yourself
        • Alex ahir
          • May 2012
          • 125
          i try 7654321 but no luck, how to go to service mode
          • Rachid.Akli
            • Oct 2011
            • 595
            Hi to all
            1-Press "Main Menu" button.
            2-Press "Additional Func" button.
            3-With the arrows or the scroll wheel, go to"ID System Management System", then press ok
            5- If you're asked to enter a password, use the "7654321" combination.
            6-Go to "Network settings" and press OK.......
            Good luck.
            Rachid.
            "Find a job you love and you’ll never have to work a day in your life." Nagy's father
            • zoraldinho
              • Mar 2008
              • 4964
              If you don't know canon service mode code,you have nothing to do in.
              • Alex ahir
                • May 2012
                • 125
                Hello everyone,
                for canon IRC 1022 to enter the sevice mode you have to press main menu than 2 and 8 and main manu,
                I was pressing additional function and 2,8 but i can not able to go in but i try some more function and it works for me.
                so many guys they dont know how to go in service mode on this model. This will add more knowledge to your technical field.
