ir2022 how to reset the whole machine to default?
  • PrintMe
    Time to time the copier stops printing, you can send a job to it, and after 30 sec or so get error massage.
    Reinstalled drivers, restarted printer computer and even a coffee maker, still no luck!
    I would like to reset everything to defaults and start over again. Machine worked fine before.
  • doktor
    • 214
    Re: ir2022 how to reset the whole machine to default?
    Try with new firmware.
    • tones27
      • Jun 2012
      • 18
      you can try doing an all clear in service mode and after that put back all the values in the machine they are located on the rear back cover of the copier best regards
        • 22929
        I'm sorry. I can't ignore the bad advice offered here.
        Please don't do an All Clear. All you will do is create new problems to add to you old problems.
        For starters, try doing a little real troubleshooting and look up the error message that you get, or post it here if you're unable to read a manual. I'm sure someone here can read for you.
        • arielcanon
          • Mar 2012
          • 106
          Try to clean/change Ram with another..,
          Learning never ends..
          Never give up, where there is a wheel there is a way..
          • teckat
            • 16083
            U POST NO ERROR CODES ??
            the object of being a good tech is to have and follow a procedure on service calls/
            it's all about> the process of elimination
            there are no quick fixes/no band-aids/hit & runs for imageRunners-
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Can you say USER
              • COPIERTEC ASSOCIATES
                • Aug 2011
                • 279
                Have you tried to change the printer cable you are using? This machine uses USB port or ethernet port to print.Sometimes this cables can become a manace.Try to change the cable .
