Here is the trouble,The machine boots normally and comes to standby screen but when the Start (Green) button is pressed to make copies, the scanner does not move at all; however the screen will display 'Printing Completed'It is observed as follows,
1. The is neither displayed in the service mode level 1, nor is in,
2. If you press the 123 button, under Device Configuration, the Scanner version is displayed 0.00,
3. The READER PCB and DIFFERENTIAL PCBs were replaced but no change.
4. If a doc is placed in the FEEDER, is detected, which shows the power supply is there,
5. When the I/F cable was disconnected, E732 was NOT displayed as would be the case.
6. The machine prints from PC, only copying is a problem.
Please guys, I need your help. The machine previously had a HDD failure, a used one was fitted and it worked fine for two months before this fault.Regards!
