Canon IR7105 #code E110
  • Thailandonly
    • Aug 2025
    [Dead] Canon IR7105 #code E110
    I have repaired and then found that I had some problem in Laser Diode. But I could not find the source to buy it. Because of I do not know detail of this. Who know the detail of Laser Diode and the source to buy it, Please let's me know. Thank you>>
  • teckat
    • 16083
    Re: Canon IR7105 #code E110
    [ATTACH=CONFIG]16542[/ATTACH]
    LINK>>
    Circuit Board Repair for Canon, EFI Fiery, HP, KonicaMinolta, Kyocera, Ricoh, Sharp & Toshiba
    • RRodgers
      • Jun 2009
      • 1947
      AJ's the man over there. Mad props
      • spectraindo
        • May 2008
        • 313
        E110 on IR7105 is usually the Laser shutter closed while the machine is ON, check all covers are in place , specially the Primary corona cover which opens the shutter when installed.
        • Thailandonly
          Many thanks for your Suggestion and Nice to know you. I will search from your link and find out. More question please, does it has the other Laser-diode for replace this one? How many nanometers in laser-diode and How many out put power? Thanks for your kindness again!
          • spectraindo
            • May 2008
            • 313
            Do not replace the Laser diode yourself, even if you can find it, you can not adjust the Laser beam precisely, because the Laser beam is invicible.
            Replace the Laser scanner as a whole unit.
            • Thailandonly
              Thank you so much... I ever been solved scan laser 's problem by changing Laser Diode. It was success. I found Laser Diode from the old machine. But nowadays, it hard to find that. Please tell me about this Laser Diode's detail and source of this Laser Diode. Thank you so much again!
              • spectraindo
                • May 2008
                • 313
                Well, sorry I do not know the part number of the Laser diode.
                For Datasheet of Electronic components visit : ALLDATASHEET.COM - Datasheet search site, Datasheet search site for Electronic Components and Semiconductors and other semiconductors.
                To order Electronic components online : www.digikey.com
                • Dimacop
                  • 43
                  Hello friend
                  You could solve the E110 Thailandonly
                  which model you pulled the piece because I am having the same problem with my laser
                  thank you
