canon np 6560
  • lkrsardis
    • Dec 2007
    • 316
    canon np 6560
    hello out there, I have this np6560 with the rdf-d1 that when you put multiple originals and use the right feed it won't stop copying. Any ideas? Thanks
    Like the United States Postal Service It's a miracle it works!
  • kwazimoto
    • Jan 2007
    • 199
    the first thing i would look at is doc.detect unit (black flags that come around and hit the paper on rear side of a original copies)on the tray if it does not go to home position it will just keep running the copies thru..
    the part number for the unit is FG2-6776-000 the end of one side is folked and it will brake off...
    • lkrsardis
      • Dec 2007
      • 316
      np6560
      Thanks, I'l check that in the morning.
        • 22999
        Kwasimoto is right on the mark:
        Continues recopying same originals endlessly. Broken recycle motor shaft for flags. Temporarily slip an 8 mm long section of thermistor wire covering over the shaft/motor linkage to keep both parts aligned. Replace shaft for flags next call (FC2-1500-000).
        This is a good repair. I've had machines run a year or more with just that little piece of rubber tubing holding it together.
        • lkrsardis
          • Dec 2007
          • 316
          NP6560
          Thanks guys I'l try all these suggestions today. It's funny how even though I;m trained on this machine how you forget these little tricks.
          • lkrsardis
            • Dec 2007
            • 316
            rdfd1
            Thanks Blackcat and Kwasimoto, that was it.
