ir2230 reboots
  • repeatcopiers
    • Sep 2008
    • 591
    ir2230 reboots
    We have an IR2230 in the field that reboots itself when you press the Start button, it also doesn't recognize the cassette trays, when you press Paper Select is looks as if no trays are in the copier. Per Hytecs suggestion we have replace the Main board but still having same issue.....any ideas?
  • repeatcopiers
    • Sep 2008
    • 591
    Re: ir2230 reboots
    Well just thought I'd update what we found........We missed the fact that someone had turned both paper tray dials all the way to where theres no size indicator!
      • 23006
      Re: ir2230 reboots
      ... and this makes the machine re-boot when Start is pressed?
      Somehow there must be more to it than that. =^..^=
