Canon IR1600 - Replace toner/Mixing toner
  • Smiley27
    • Apr 2011
    • 160
    [Misc] Canon IR1600 - Replace toner/Mixing toner
    Hi folks,
    Right after I turn on machine it start to mix toner, after mix I make one copy, and I get message to replace toner..
    Toner inside is new..
    Any suggestions what could cause this?
  • Mina Banoub
    • May 2011
    • 50
    Re: Canon IR1600 - Replace toner/Mixing toner
    Originally posted by Smiley27
    Hi folks,
    I recommend that you carefully clean the rear side of the developing assembly that contains the H.V contacts , make sure there is no residual toner or rust over these contacts. If after cleaning u still have the same issue replace the high voltage pcb.
    • mramlawi
      • Jul 2011
      • 838
      Make sure that u r using geniue toner this toner problem replace it again.
      Distinguished road makes you jewel in rough
        • 16083
        Hi folks,
        did u work on dev. unit first
        if so>make sure the reinforcement plate that is behind the cleaning blade is present--
        • montana
          • Aug 2008
          • 392
          Hi folks,
          hi....i will give a suggestion...there is potentiometer adjustment on the HVT board which located under the laser scanner unit it is marked with ANT...i tried this once and it is succeed...good luck
          • jrgf67
            • Feb 2010
            • 37
            Greetings. Changes the developing unit and do a master clear.
            • mramlawi
              • Jul 2011
              • 838
              Bravooooo
