ask for help Canon service support tool Registration is not complete.
  • makmee
    • May 2012
    • 24
    The problem is.Register Successfully Fromcanon7105copyer But no list
    Please See illustration
    Thank you all Comment
  • teckat
    • 16083
    Re: ask for help Canon service support tool Registration is not complete.
    u don't have iR7105 selected in your SST Pic/ u have another model iR5075 shown that is not registered correctly
    what model are u talking about ????
    u did not register the firmware correctly/
    it is not under new rom
    click on pic for better view
    it is under C:\Canon File Folder\SST System Software Folder\SST Files\iR7105_V2_v80.02
    • makmee
      • May 2012
      • 24
      [ATTACH=CONFIG]16698[/ATTACH]
      Thanks for the idea.Now as you suggest
      Successfully.I lost the rcon I have
      Newer versions. Who It helps.
      Please send me makmee@ymail.com
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5009
        What exactly you need?
        • makmee
          • May 2012
          • 24
          rcon specific or As far as possible.Thank you very much
          • zoraldinho
            • Mar 2008
            • 5009
            Copier model?
            Firmware version?
            Language?
            • makmee
              • May 2012
              • 24
              Copier model?
              Firmware version?
              Language?
              sorry
              i need Firmware canon iR7105 for all or
              -rcon
              -system
              • teckat
                • 16083
                sorry
                -rcon
                -system
                look in the 7105 folder for RCON > C:\Canon File Folder\SST System Software Folder\SST Files\iR7105
                u then need to uninstall and re-install 7105 firmware
                u have old firmware _ it is now up to v80.02.03as of 12/1/2011
                11-16-2007
                System Software v55.05 for the imageRUNNER 7086/ 7105/ 7095/ 7095 Printer V2 has been released. Version 55.05 provides the new, robust feature set of the new V2 engines. Any imageRUNNER 7105 series engine can be upgraded to v55.05 to have this new feature set.
                When installing System Software v55.05 on the older imageRUNNER 7086/ 7105/ 7095/ 7095 Printer, please follow the procedure below to insure proper installation or an error will occur.
                1. Place the machine in Download Mode by holding down 2 & 8 and powering ON the main switch.
                2. Using the Service Support Tool v3.35Ek, select the 'iR7105' Folder/ 'SINGLE' and install 'Special BootROM v10.99'.
                3. Turn OFF the Machine and then back ON holding 2 & 8 to place back into Download Mode.
                ***Once the BootROM is re-written, it cannot be returned to the old model version.***
                4. Using the Service Support Tool v3.35Ek, select iR7105_V2 and perform an 'ALL PARTIONS' HD-FORMAT to the Hard Disk Drive [HDD].
                Note: Formatting using the USB Memory Stick to perform HD-FORMAT is not available and is only available using the Service Support Tool at this time.
                Once the HD-FORMAT has been performed and the machine is turned OFF, then ON holding down 2 & 8, downloading the System Software using USB Memory Stick or Service Support Tool can be used.
                5. Select 'ALL' to install System Software v55.05.
                6. Power OFF & ON Machine. The machine will extract and install the system software.
                7. When installation is completed, turn OFF, then ON holding down 1 & 7 to place into 'FIXED IP' Download Mode.
                8. Select iR7105_V2 and select 'SINGLE' to install the Accessories.
                Note: After flashing the accessories firmware by way of an ARCNET connection, be sure to select the 'SHUTDOWN' button on the Service Support Tool or the accessories will not upgrade. Pressing the Shutdown will place the 7086/ 7105/ 7096 into a pre-shutdown mode.
                • oommiiddaann
                  • Feb 2012
                  • 34
                  how i can get this firmware? like: v80.02.03as of 12/1/2011 i live in iran my work is repair canon photocopiers.but Iran have not any real canon center or canon dealers. i think i have to register on www.support.cusa.canon.com but i cant because i haven't dealer code or something else. can anyone help me ? sorry for my bad english
                  • teckat
                    • 16083
                    u need to work for a Canon Authorized Dealer for code/
                    • oommiiddaann
                      • Feb 2012
                      • 34
                      yes i know!! but my country have not Canon Authorized center for repair and support.iran just have used canon copier products. how i can download new frimware.how i can buy.how i can give?
                      • makmee
                        • May 2012
                        • 24
                        I Request from a friend.Working.of canon
                        What do you need.
                        You can help.
                        • JustManuals
                          • Jan 2006
                          • 9838
                          Look elsewhere, there's nothing for you here.
                          • cortex7dj
                            • May 2014
                            • 5
                            i have the SST but not the fimware
                            please send me the model that you have (ir5075) firmware by mail cortex7dj@yahoo.fr
                            thank
                            • aseason
                              What do you need.
                              You can help.
                              hi ! can help me how to regist firmware for iRA6275 and conenct to USB , i use the SST 4.81Er , i cant find any file in the SST 001.jpg002.jpg003.jpg
                              swtop01@gmail.com thx
