Quality print issues on ir5570
  • gizmo
    • Jul 2025
    [CQ] Quality print issues on ir5570
    Consistent 2 inch spaced marks on any size copy or print-out from a 5570.
    This appears before the fixing assy.
    Any comments would be appreciated.
  • teckat
    • 16083
    Re: Quality print issues on ir5570
    did u remove drum and or dev. unit to check surface
    • mjarbar
      From the spacing I would say the drum, it looks as though something has gone through leaving a residue of something on there!
      • teckat
        • 16083
        Check if the sponge rubber on the pre-transfer corona assembly is deteriorating and adhering to the drum.
        --clean and polish drum----
        if so replace the seal or the entire pre-transfer corona assembly.
        Seal, Post FB2-6930-000
        Pre-Transfer Corona Assembly FM2-4217-000
        • Paul 75
          • Oct 2008
          • 97
          That looks like hardened toner on the dev roller..... normally caused by generic toner ( which im used too !!! )
          Oh...... I can't copy at the moment then ? !!!!!!
          • montana
            • Aug 2008
            • 392
            yes... i agree with paul it is a toner quality issue ..clean the developing assembly and put a new fresh toner.
            good luck
            • Lee251
              • Jul 2012
              • 5
              I agree... a dirty developing cylinder. This could also be caused by worn spacer rollers.
