ir 4570
  • walidcharifi
    • Feb 2011
    • 379
    ir 4570
    I have a problem with my ir4570 *finisher*
    WITCH The End of the page / A3 only /
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: ir 4570
    copier > adjust>fixing> fx-fl-sp (+3)
    clean rollers in the upper delivery unit
    Replace the 2nd Upper Delivery Unit
    • teckat
      • 16083
      Re: ir 4570
      help me[ATTACH=CONFIG]16748[/ATTACH][ATTACH=CONFIG]16749[/ATTACH][ATTACH=CONFIG]16750[/ATTACH]
      to add on-----------------------do u also receive a jam code ??
      Finisher -slightly z fold towards the trail edge of the paper.
      Perform a voltage check on PI33 to verify a state/voltage change. If there is no state/voltage change replace PI33. If no voltage is found to PI33 replace the Finisher Controller PCB.
      If this jamming occurs after the Finisher Controller PCB has been replaced perform all of the adjustment to the new Finisher Controller PCB as specified in the Q3 Service manual
      • walidcharifi
        • Feb 2011
        • 379
        Re: ir 4570
        THANKS
        2nd Upper Delivery Unit,,,,,,,,,?????????????????
        NO SERVICE MANUALE
        HELP ME WITH PHOTO
        PLZ
        • teckat
          • 16083
          Re: ir 4570
          THANKS
          NO SERVICE MANUALE
          HELP ME WITH PHOTO
          PLZ
          • Beurun
            Re: ir 4570
            Do what second poster has said, Change all 3 to plus 3 and clean/replace exit rollers. You dont need to replace the assembly. Very common problem.
            • teckat
              • 16083
              Re: ir 4570
              • walidcharifi
                • Feb 2011
                • 379
                Re: ir 4570
                Originally posted by teckat
                [ATTACH=CONFIG]17295[/ATTACH]
                thank youI trycleaning
