i have a canon 3300 with an error code E000733-0000 have tried a few things but cant come up with a fix help plz.
canon 3300 error code
nilsonmorales
error comunication printer
a fault is detected by the main controler pcb in the comunication between the dc controller pcb and the main controler pcb
en otras palabras es un error en la comuncacion del printer yo te puedo pasar el manual si queres nilsonmorales@hotmail.com agragame a tu msn -
From the service guide:
Is the connection between the connector J1015 on the main controller PCB and the connector J316 on the DC controlled PCB normal?
NO: Correct the connection
YES: Replace the DC controller PCB.
MY NOTE: I would look real close at the connector pins. A bent pin is a bitch.Comment
blackcat: Master Of The Obvious =^..^=Comment
e733
Like the post that blackcat referred too, this was a problem when the machine was first introduced. Also check the wall voltage, no more than 3 volts between neutral and ground.Like the United States Postal Service It's a miracle it works!Comment
