good morning,from what i can gatherthis machine had a paper jam and the user just shut the machine off and walked away.now this error appears at start-up... 584-0001i know that its an issue with the finisher Q3/ Q4 but if somebody could give me a push in the right diriction that would be great.thanks.
3035 Error 584-0001
Re: 3035 Error 584-0001
From canon imageRunner 3035 3045 3530 3570 45704 canon: canon imageRunner 3035 3045 3530 3570 45704 canon imagerunner error codes IR copier canon imagerunner error codes IR 3035 * 3045 * 3530 * 3530G * 3570 * 4570 2525 * 2530 * 2535 * 2535i * 2545 * 2545i Title : E584 CodesProblem : If the Optional Bin B1 is installed, various Error Codes may result if the Finishers cover screws are not all installed and fully tightened Solution : The covers on the Finisher S1 and P1 are an important part of the Finisher frame, if all the cover screws are not installed and tightened the frame will flex excessively. The most common problem when the optional Tray- B1 is installed is that the shutter will intermittently contact the upper or lower bin resulting in a loud noise and / or E584 Codes. Product : imageRUNNER 2270 / 2870 / 3570 / 4570 Finisher Q3 -
did u check for jam paper blockage/ or jam codes ?
check the Shutter Drive Assembly**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
well im not exactly sure what i did...but i took it apart, checked the shutter, put it back together, and now it works.Comment
( turns out I had the finisher wrong, it was the S1 finisher)
And the issue was the spring on the arm of the shutter.... The spring was placed to pull the shutter down, and was interfering with the shutter moving up.
Gravity should pull the shutter down? Correct?
So I removed the spring, and it fixed the problem.Comment
and i do have a couple of good spring hooks... actually one is for corona wire but it has been quite usefull as a spring hook as well.Comment
I dont know where the tech pub is but after thinking about this Im not sure why a 3035 would not have ALL the updated S1 Finisher parts already installed! Sounds like your problem Was and IS the spring. Memory says the 4570 series was victim to all the older parts and old style controler.Comment
Last edited by teckat; 08-16-2012, 05:19 AM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
