3035 Error 584-0001
  • nogood boyo
    • Mar 2012
    • 156
    3035 Error 584-0001
    good morning,from what i can gatherthis machine had a paper jam and the user just shut the machine off and walked away.now this error appears at start-up... 584-0001i know that its an issue with the finisher Q3/ Q4 but if somebody could give me a push in the right diriction that would be great.thanks.
  • huli
    • Nov 2009
    • 8
    Re: 3035 Error 584-0001
    From canon imageRunner 3035 3045 3530 3570 45704 canon: canon imageRunner 3035 3045 3530 3570 45704 canon imagerunner error codes IR copier canon imagerunner error codes IR 3035 * 3045 * 3530 * 3530G * 3570 * 4570 2525 * 2530 * 2535 * 2535i * 2545 * 2545i Title : E584 CodesProblem : If the Optional Bin B1 is installed, various Error Codes may result if the Finishers cover screws are not all installed and fully tightened Solution : The covers on the Finisher S1 and P1 are an important part of the Finisher frame, if all the cover screws are not installed and tightened the frame will flex excessively. The most common problem when the optional Tray- B1 is installed is that the shutter will intermittently contact the upper or lower bin resulting in a loud noise and / or E584 Codes. Product : imageRUNNER 2270 / 2870 / 3570 / 4570 Finisher Q3
      • 16083
      did u check for jam paper blockage/ or jam codes ?
      check the Shutter Drive Assembly
      • Lee251
        • Jul 2012
        • 5
        Check the finisher tray supports (the one with the white rollers). If they are bent, the tray will not go up and down smoothly and will cause noise.
        • nogood boyo
          • Mar 2012
          • 156
          well im not exactly sure what i did...but i took it apart, checked the shutter, put it back together, and now it works.
          • Simons
            • Jun 2008
            • 490
            Good to here.
            There were updates for the 3570. Controler / lower sensor flag with spring! / make sure tray motor screws stay tight!
            • nogood boyo
              • Mar 2012
              • 156
              Originally posted by Simons
              Good to here.
              This error popped up again,
              ( turns out I had the finisher wrong, it was the S1 finisher)
              And the issue was the spring on the arm of the shutter.... The spring was placed to pull the shutter down, and was interfering with the shutter moving up.
              Gravity should pull the shutter down? Correct?
              So I removed the spring, and it fixed the problem.
              • Simons
                • Jun 2008
                • 490
                they redesigned the flag. I think it was made just a little longer. Im not sure about just removing the spring. I put the new style flag on and put the spring back on which was a pain. Better have a nice spring hook tool.
                  • 16083
                  FLAG WITHOUT SPRING = Help Me.jpgin FUTURE
                  • nogood boyo
                    • Mar 2012
                    • 156
                    Originally posted by teckat
                    FLAG WITHOUT SPRING = [ATTACH=CONFIG]16886[/ATTACH]in FUTURE
                    damnit. i was a little worried about this. temporary solution i guess.
                    • nogood boyo
                      • Mar 2012
                      • 156
                      Redisigned the Flag on the Finisher-S1?
                      and i do have a couple of good spring hooks... actually one is for corona wire but it has been quite usefull as a spring hook as well.
                        • 16083
                        • Simons
                          • Jun 2008
                          • 490
                          I dont know where the tech pub is but after thinking about this Im not sure why a 3035 would not have ALL the updated S1 Finisher parts already installed! Sounds like your problem Was and IS the spring. Memory says the 4570 series was victim to all the older parts and old style controler.
                            • 16083
                            E584 – 0001.pdf
                            or------------replace Shutter Drive Assembly-4G3-0407-000
