Some spoiled customer has a subcontract with us for a iR3245.
Copier works fine but recently has a whistling noise (which apparently is unbearable for the boss).
Anyway I went to check (without tools) and it is hard to tell where exactly is the noise coming from.
I did a motor check and it was M2 (the main motor).
I wouldn't like to go back and tear apart half of the copier.
Anyone had this issue and a Short-Cut solution ?
Thnx...
Thnx...
