canon ir 1210
  • esam ramadan
    • 199
    canon ir 1210
    the copy was very good after somebody changed the software it now very light how can i make it darker thanks for help
  • teckat
    • 16083
    Re: canon ir 1210
    ------------------------------------Glass copies or Network prints or both ?? -------------------------------------------Call back the "Somebody" person
    • esam ramadan
      • 199
      Re: canon ir 1210
      hahahahah i don't know him the problem in copy - i dont use printing
      • montana
        • Aug 2008
        • 392
        Re: canon ir 1210
        hi....maybe someone has played with setting like toner save mode....so you should clear the memory to make sure....have a good luck
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5018
          Re: canon ir 1210
          Can be a simple like, text/photo button.Maybe someone change toner incorrectly.Try to reinstall drum and toner.
          • arielcanon
            • Mar 2012
            • 106
            Re: canon ir 1210
            Use OEM toner, Is the surface of the developing cylinder coated with an even layer of toner?
            Learning never ends..
            Never give up, where there is a wheel there is a way..
            • esam ramadan
              • 199
              Re: canon ir 1210
              how can i clear the memory ? thanks
              • teckat
                • 16083
                Re: canon ir 1210
                have you found the somebody who worked on machine ??????????????????
                • esam ramadan
                  • 199
                  Re: canon ir 1210
                  not yet boss
