I have an Canon IR 2000 that can not start. I'm now thinking of firmware error. Could anyone send me that firmware through my mail kazihaha@yahoo.com? Please help me. Thanks in advance.
Canon IR 2000
Re: Canon IR 2000
Please explain "won't start" issue!If it ain't broke, don't fix it
A picture is worth a thousand words -
Re: Canon IR 2000
DearI replaced the hdd with the other one from a working machine, and it worked.So I think here the hdd and the firmware have problem. But in case the hdd problem, how can I copy the firmware from the working hdd to my hdd (i got some old hdd from laptop that have the same type with the broken one) and place it back to photocopier Canon 2200F. Is it work? I mean copy firmware from the working hdd to the new and how can I do that?Thanks for your helping.Comment
Re: Canon IR 2000
Try HDD cloning. For details on how to do it, contact a guy called 'zaza', who is also a senior member of this forum. He seems to be an expert in that area.
Good luck.Comment
Re: Canon IR 2000
Am a bit confused with this IR2000 model having an HDD.I need to be educated on this.Otherwise i may propose that the model in question could be IR2200 thanks.Comment
Re: Canon IR 2000
Specifications iR1600 / iR2000
Printing (Optional)Hard Disk: 10GB (Optional) A 10 GB hard disk can also be added to provide storage and spooling facilities for network printing, improving printing efficiency.
Network Connectivity: USB, Parallel, Ethernet (10/100BaseTX) (Optional)
Network Protocol: TCP/IP (LPD/LPR), IPX/SPX (Pserver/NDS/Rprinter/Nprinter), AppleTalk (PAP)
Supported OS: Windows 95/98/NT4.0/2000/ME/XP, Mac OS 7.5 or later, Solaris 1.1x, 2.5 or later
Optional Accessories:
ADF, Finisher, Inner 2 Way Tray, 32MB Memory Expansion, Card Reader, Cassette (1 tray), 2 tray iR 2000 only, 3 tray iR 1600 only, Pedestal, Printer Board,
Ethernet Network Interface adapter, Postscript Module, Hard Disk, Flash ROM Module**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Re: Canon IR 2000
In my case, I think the hdd got problem, so how can I copy all data from my working hdd (as mentioned above) to a new one? And it will run without problem?Comment
Re: Canon IR 2000
Any recommended software for me ^^?And how can I "be sure that the hdd is of same type and supported by machine"?Comment
