IR4570 RemoteUI Contents is Not Found!!
  • goldencup
    • Nov 2008
    • 366
    Hi, I have iR4570 machines that when accessed through web always show:
    RUI Module Version : 3601
    On one of the machine, I try to replace the hard disk taken from a good unit. The machine works and can now access the RUI. Does it mean my other unit has also a problem on HDD? Is it okay if I format the disk and clone it coz i don't have SST right now.
    By the way i did an HDD check, all are OK!
    Copying, Printing and Scanning are all okay, I just can't access the RUI.
    Any other solution from this? (or maybe this is not an HDD problem ) Thank you very much.
  • Mina Banoub
    • May 2011
    • 50
    Re: IR4570 RemoteUI Contents is Not Found!!
    Hi ,
    I think that you have to download the RUI to your M/C using SST(batch download-singl mode) or You can make a copy from the firmware registersrd on the good HD that you have replaced, to your M/C`HD.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5013
      Problem can be solved with SST and complete firmware.HDD is OK.
      • goldencup
        • Nov 2008
        • 366
        is it okay if I defrag the HDD? (Hold 1 & 9 key) Will it do the trick?
        • KL568
          _
          • Feb 2011
          • 324
          Hi,
          Try to see if there version number for RUI under Service Mode topic ""Version"
          If it a "--", that could be the issue you facing
          • tenatal
            • Aug 2011
            • 35
            Nothing will happen by doing this, there is no tricks like this.
            Earlier posts by other user already show u the correct way.
