ir 5055 e100-001
  • Luther
    • May 2006
    • 682
    ir 5055 e100-001
    Machine threw code e100-001 took the laser and put it in a different machine to make sure the laser was bad and it coded out so i know the laser is bad, put a new laser in and still throws the code, repalced dc controller and still have the code,put the new laser in a different machine and it works fine .2 different dc controllers and still has the code , i might be missing something obvious, checked shutter and fan cover to see if the pin is broken shutter works fine,i know the laser i put in is good it works in another machine and the one that codes does it in another machine, any thoughts?
  • tenatal
    • Aug 2011
    • 35
    Re: ir 5055 e100-001
    did u clear error after replacing laser, also should try clear dc-con, mn-con
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      Nice thought but don't clear all in a row!You can spend all day on this copier.
      • Herrmann
        • Jan 2006
        • 792
        Did you check the door switches?
        Did you check the DC Power Supply if 24v is all present?
        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
        • Rachid.Akli
          • Oct 2011
          • 595
          Hello,
          When working on machines, we sometimes cause new issues which are difficult to solve (they are not ordinary). There are three elements to be suspected: 1- Laser unit. 2- Dc contrller. 3- The connexion between the two. When you've pulled the laser connector, you might have created a loose connection. Try to replace the wirings.
          Rachid.
          "Find a job you love and you’ll never have to work a day in your life." Nagy's father
          • teckat
            • 16083
            Check for proper voltage from DC power supply to DC Controller
